    TIPS:
Phenolic Intercooler for your Gen3/Gen5 M90, L67/L32 3800's - LOOK INSIDE
Status
Not open for further replies.
Re: Phenolic Intercooler Gen 3 Gen 5 L67 L32 Eaton M90 SuperCharger 3800
One sold and one left ready to go.
This is a great intercooler.. Recently installed one and I have no complaints..
Any Gen V's? Looking to get one soon. Basically this is just the core and I need the FMHE, hoses, pump, and gaskets? If so whats recommended? Does the 04+s need the turn down adapter for this IC? Sorry if this has been addresses I'm on tapatalk.
There is a lot of info in the first post, but I do have one intercooler ready to go. I can set it up as Gen 3 or Gen 5 doing the final machining before I ship.
In short here is my recommendations.
The bosch pump is ¾ barbed fittings. The hose and FMHE will be ¾ barbed fittings from frozenboost. The phenolic intercooler is 5/8 but with the fitting and 2 molded hoses from summit racing you convert to ¾ hose.
Frozen Boost
1 ¾ Water to Air Intercooler Installation Kit (350/600HP) [WAT001012]
2 ¾ Water to Air Intercooler Pump and Harness, Bosch Cobra [WAT001001]
3 (6) Stainless Steel 0.75" Worm Gear Clamp (13-23mm) [CLA001030]
4 FMHE to fit your vehicle.
Summit Racing
1 (2) ¾ to ¾ Dorman Heater Hose Connector Fittings 47095
2 (2) ¾ to 5/8 Goodyear Molded Bypass Hoses 63726- SummitRacing.com
3 Loctite 37464 - Loctite RTV Gray Silicone Gasket Maker $5.99—--Loctite 37464 - Loctite RTV Gray Silicone Gasket Maker
Also need modified fuel rails from the 3800 vendor of your choice. Intense, ZZP, Wbody store.
Do you have any left?..looking for a genV
Yes for gen 5. I have intercooler ready, manifold will take a week if you need one
Hello, I am curious what type of Phenolic material you are using. Is it Bakelite: Made from wood flour and phenolic resin, or is it Novotext, Paxolin, or Tufnol: This type of phenolic resin is reinforced with cotton or linen fibers and is often used in applications as a liner in loaded bearings, because it has low-friction. The reason I ask is because in the 2 videos of yours that I have seen the material looks like and behaves a lot like UHMW: Ultra-high-molecular-weight polyethylene which also carries decent insulation properties. The reason I ask is just so I am sure exactly what I would be buying.
In using Garolite from McMaster Carr.
CNC computer won't boot so phenolic intercoolers are on hold. Retrofit of machine can be very costly so I won't have intercoolers for awhile.
do you know what the typical pulley drop this intercooler will support?
With your intercooler I would be able to drop 4 pulley sizes?
Doing an XP cam ls1 maf and Northstar setup with Gen V supercharger on my 97 in 2 weeks. Does your inter cooler come ready to bolt to my setup
Status
