PCM problem??
Well...Marine has a post about stuff. Others have posted links around where to get schematics and most libraries have the schematics. If you are lost.. I can help guide you... can't do the work though.
I haven't read this thread yet. Just saw someone needs a schematic, ill post one up later for you.
Sent using my Galaxy SIII on Tapatalk 2
Skimmed over it. Your check engine light should be on with ignition on AND crank. Shuts off (assuming u have no codes) once running. No ces light means no response or the pcm just isn't getting powered up
