PCM mounting ?
JT2002GTP
Do I need to get the PCM mounting plate, or can I just drill holes to mount PCM on 02 gtp . What do you guys do ?Thanks.
I put a heavy bead on the shelf an let that cure, then sat the PCM on top of that and used thick assed zipties to hold it down.
if you want to mount it to something other guys on here have used s10 pcm mounting plates and just drilled new holes for that... mines ziptied and does just fine
