Parameters to look at on torque app
I have fuel trims, engine and trans temp, percent throttle, IAT temp, AFR, and timing. Then I have a whole spark plug page, for current and history of missfires
Nice, I tried logging afr but it wouldn't let me :th_scratchhead: do i need a wideband connected? Also it seem's like I can't get a lot of parameter's that other's can get like Trans Temp, AFR, Oil pressure, and Oil temp among other's. I do have a tuned pcm if that makes any difference.
did you go to settings and set it to the GM settings?
Settings>Manage extra PIDs/Sensors> Add Predefined Set> Pontiac/GM/Opel/Vauxhall
That should load all the sensors associated with the car so you can monitor pretty much everything. Some things dont work. I couldnt get oil pressure to work
Air fuel ratio/lambda readings would need to come from an actual gauge for a wideband/lambda sensor. A phone app can't do that.
And our cars couldnt read oil pressure either as its only got a dummy light, not a real sensor for reading psi.
ugh that's lame considering oil pressure it pretty important. I'll try the GM setting and see where that gets me.
My Bonneville reads oil pressure. In any case, I have coolant/trans temp, IAT, KR and some other stuff. Battery voltage.
