Hi everyone!
I just got this code on my car in along with a P0301 Code - Cylinder #1 Misfire. Is it possible that the misfire is causing the crankshaft position sensor code?
I got this info from http://www.obd-codes.com/p0335: "Depending on the vehicle, the PCM uses this crankshaft position information to time the spark properly or on some systems it is only for misfire detection and does not control spark timing."
All in all, I'd like to know if the crankshaft sensor needs to be replaced.
Thanks in advance!
Thanks in advance!
