colindunn
2004 Grand Prix GTP CompG
-Knock Sensor voltage low bank 2 CODE P0332
-Cylinder 3 misfire (not bad though so no code came up for it)
-car bogs down and has loss of power much more noticable at light throttle.
-also when going around 35 in 3rd gear, i give it some gas so it drops into 2nd and before this problem it would have some pull to it. now when it does it accelerates slower.
so ive replaced my knock sensor twice now since the code came up for the first time. the first time i replaced it the problem got a little better. the second time i replaced it 2 days ago the problem seemed completly gone. except came back a day later but its not too noticable.
the power lag is only noticable at lighter throttle, then kicks in as you press the gas further.
I connected an ethos scanner to it. knock sensor code came up but when i went into engine diagnosis for misfire, cylinder 3 was missing occasionally but i guess not enough to trigger a misfire code? so im thinking thats what could be triggering the knock sensor code???
ive replaced the plugs and wires. put coil packs on it from my 2001 grand prix since the contact points looked a lot better. (the ones on my 2004 one had a bunch of corrosion on it.)
check engine light still comes on after driving for the knock sensor but it has to be something else right?
only mod is an intake. ANY help is appreciated. need to figure this out i dont know where to go from here.
when the knock sensor was replaced everything was torqued properly and coolant refilled both times. so im almost positive that is not the problem.
