p0172
02gtp40
hey guys got a 02 gtp light mods cai, port and polish intake a s/c 3.4 pulley and a throttle body spacer car threw a p0172 fuell bank 1 is too rich. i changed the 02 sensor and cleared the code 2 days later it came back. i found a vaccum leak on a three way connector that comes off the intake and fixxxed it code just came bak a month later??? idk what else to do
Spray carb cleaner on that TB spacer... if your idle changes.. you found your vac leak.
Better yet go buy a 30 buck boost gauge and hook it up. That will tell you if you have another vac leak.
1. put the stock pulley on.
2. Check and see if the FPR is leaking into the vac line and check fuel pressure.
ive had this same code for about a month now. is it possible it could be the O2 sensor? all i have is a cai right now.
the light was on before the pulley swap o2 sensor already changer im gunna spry the spacer tonight and see what happens.. and i really should get a boost gauge too just cant decide what mounting i want yet
think i found my culprit i sprayed my maf with cleaner and now it isnt doing it i need to just replace it any one know of a "better" aftermarket one or ill just put in oem
hmm. i replaced my MAF because of a code that said the voltage for the maf sensor was high or something. i would think if it went bad again i would get the same code. i did get a cheapo from a junk yard.. could be the problem.
