Stappen720
so i finished installing my trans and im now having problems with the trans not shifting gears correctly. It sometimes skips gears and sometimes feels like 1st gear revs longer than its suppose to to shift into 2nd. I also got a SES light that says P0121 - Throttle Position Sensor/Switch A Circuit Range/Performance Problem. So i changed the TPS and its still doing the same thing. On my HP tuners vcm scanner it says my IAT is running really hot at idle. I have never seen it pass 105* at idle and its hit 172* degrees. Im also noticing that my boost gauge isnt working now and my blow off valve isnt blowing off. So i checked vacuum lines and i havent seen anything unusual, or hear any unusual sounds to me. One thing i noticed is that when i rev the engine my boost bypass doesnt open up but i cant remember if it ever did since i went turbo. Hoping to get someone who has a turbo for that question. Also when i accelerate in park slightly the peddle stays accelerated and slowly drops down. When i looked up what symptoms the TPS does it did say something about that happening. After i changed TPS i didnt really drive to far but i didnt get any codes for it yet. Any questions ask please. thanks guys
