Opinions on SLP air box.
WhiteGT
I am looking at buying an slp airbox and was looking for some opinions on these particular setups. They don't look too much different than the stock airbox aside from not having the baffles in the box and using the cone filter instead of the stock type. Would this be worth buying or would just throwing in a k&n filter in the stock box be good enough? My car is just a daily driver.
Thanks!
there is plenty better intakes than SLP's. Wizard is the best and then there are fender well intakes.
Don't put in a k&N drop in filter, with my experience the oil on the filter clogged up my MAF sensor, therefore i had to replace it. K&N drop in's are a rip off. No performance what so ever. Save your $50.00
If you had oil on you're mas air flow sensor then you over oiled you're filter.
Yeah a lot of people do over oil theres though. In my opinion they are overoiled from the factory. If you look at the bag they come in there's oil all over the bag.
Hmm, I have heard something before about the oil on the k&n's being bad for maf sensors. I figured as long as it was not over oiled it would be fine. I looked at the one for our cars and it is quite a bit thinner and less restrictive looking than a stock paper filter.
