Old Thread
Re: Really Confused With This Loud Clunk That Has Not Gone Away.
jack it up and kick the **** out of everything?
I was going to say subframe bushings, but man even something simple like that. Of course it takes someone to not tighten a bolt all the way though.. lol.
Also being that it makes the noise while stationary is a good time to have a helper check around and listen for the clunk.
Re: Really Confused With These Popping Noises Coming From My Car
1. Kinda sounds like a strut mount issue, but I can't say for sure. Seen new mounts make noise.
2. Maybe the rear sway bar bushings/links making the noise?? Spray em with WD40 or something before you drive it and see if the sound kinda goes away.
I had a very annoying squeak that sounded like it was coming from the rear speaker deck, it turned out to be the trunk lid hinges, It was from what looks like the head of a small bolt head (adjustment stop maybe) making contact, all I did was put a small amount of grease on both left, and right side hinges, all has been totally quite.
Not trying to be a jerk, but IIRC you had a mechanic do your installs.
Consulting him might be a good starting point.
Maybe the intermediate steering shaft for the front.
In the rear maybe the gas tank heat shield.
Just throwing things out at ya
Re: UPDATE: Weird Noises Coming From My Car
There is this noise that I have been having for awhile and its sound like its coming from my trunk. Every time I brake from a slow position such as in reverse (louder) or coming to a stop there is this loud thud. Originally I thought it was my sway bar links bushings and struts. Since I have change both my rear sway bar links and struts/mounts, I have no idea what this loud thud especially when braking in reverse can be. Anyone know what it could be?
It's the sound of a dying platform saying, "Please...just let me die!"
Re: UPDATE: Weird Noises Coming From My Car: Audio Included
have someone shake the **** out of the car and look under
