oil question
jamar22
Im getting ready to put my car back together from having to change the uim and lim gaskets my car did the milkshake effect.So my question is should i drain all the oil outta my car before i put it back together or is it safe to wait till after i get it back together???
Get it back together...then drain the oil/change the filter. I always run a junky cheap quart through the lifter valley before reassmbly and through the valve cover once it is all done.
But I probably over it do it...better to be safe than sorry IMO.
But yeah...put her back together and change the oil is the short answer.
well you should pour about a quart of oil in the lifter valley before you put the top end back on it. before you crank it, do an oil change. run it for 5 minutes, do another oil change. THEN you are good to go if you have no leaks :)
