Here lot of picture of my work. I do a write up soon.
Part 1 tran mouth, tran pan.
Jack up car and put on jack stand.
I remove my front bumper cover. To make more room. To work.
Take off front tires.
Disconnect battery
Remove coolant reservoir
Remove Top motor mounts
Connect support chain from alternator bracket to top motor mount bracket. I added a piece of heater hose to protect my new alternator
Loop 2 support over motor mount bolt.
Hook chain to fender engine support bar.
Crank up support bar over side wing nuts.
Pick up motor up by 4 to 6 inch. Pull out tran mount.
Old on top new below.
Next I remove all 20 tran bolts
Watch after taking out the back10 bolt fluid will start to come out.
"No picture"
My tran pan. Just black particles.
Clean everything with brake clean, remove tran filter.
Also the remove black gasket on old filter. (Big pain in the ass)
Install new gasket.
"no picture"
Install new tran filter
Install new tran gasket, and pan.
I start by putting every other both in. Then the other one.
"No picture"
Set to 80 in-pound,
Then 120 in-pound.
