this kinda thing... i know diff engine. but then drill a hole and put a barb fitting on it and run that hose to the intake/ air filter area that does not see boost. I have a stock breather setup using a LS1 fill adapter, works fine. Most the oil I see come out of them is rocker related, so moving the breather away from the rockers helps.
i also run 2 breathers.
So I put the stock valve cover on and after driving for 30 min I had white smoke coming out the exhaust..a lot of it. With the valve breather it didn't happen. So I put the breather back on till I get some suggestions on why it's doing it. Any ideas?
Yup! I only run one valve cover breather and have a cheap absorbant sponge type head/sweat band with the elastic cut off folded in half and tucked inside the VC breather...works great for my setup.i run 2 front valve covers, 2 breathers, on my twin charged setup. both breathers have a piece of foam rubber in them to keep any oil from coming out. Works like a charm. havent seen a drip.
Blow-by...crankcase pressure is building up and forcing past the rings into the combustion chambers.
