Oil cap
oneredi
Hi All
I am just seeing if when you take off the oil cap with the motor is running. What should happens
to the motor? For me the motor dies.
What I did,ported intake, ssic, ported sc, to a 1999 n* TB
Did a smoke test blocked off the TB. Just had I small leak at TB. Fixed.
So now I take off the oil cap and its under pressure and smoke would come out of the oil cap.
I put my hand over it and it builds up pressure.
Car runs good @ wot locks in @ -4.7
I think that's all. Help
Ty
Oneredi
Pics of how you ran your vac lines to the nstar? The ssic utilize stock pcv functions so as long as the front and rear ports are not blocked, vac lines routed correctly, and you have a pcv with the oring, you should be good.
So with the motor take oil cap off motor stalls, dies.
When I did the smoke test TB covered take oil cap off smoke will come out.
So with the motor running take oil cap off motor stalls, dies.
PCV in backwards and improper sealing of PCV? If it's building positive pressure when you have your hand over the oil tower (whatever it is called), and vapor coming out indicates it's not sucking in right?
just trying to understand it not arguing the fact. The IC and N* TB I knk nothing about so that's throwing me.
Jeff
hos is the ic installed? gaskets or rtv? if its all rtv id take it off make sure the pcv holes are clear and start over.
