Oh my favorite zzp
xcwilli11
Soooo it's been over a month since i ordered my cam from zzp, is it common for this long of a wait? They keep trying to say its normal but this has really put my build on hold
Sent from my LG-D851 using Tapatalk
im sure zzp is the middle man why wouldnt you order directly from comp cams or cam motion ect. ect.?
if its a custom spec cam that is or did you order an,off the shelf cam as in xp, xpz or vs.....?
I ordered a vs cam, i didnt order from comp direct because of a black friday deal that was going on at zzp
Hell, I ordered my cam from some random Canadian near Vancouver off the fiero forum and it only took two weeks to get here with cheap shipping. Wtf zzp. Get on it.
Sent from my SAMSUNG-SM-G920A using Tapatalk
sounds like they failed to have any in stock and they had to order it to be made. more ZZP bull sh it.
Yup. Had to order it first for themselves then send it out to you. They don't grind cams at zzp. Sounds normal. Should have mentioned it was out of stock and gave you heads up of a turn around time
screw that cam tell them to refund you and get one in the classifieds or on tcg or clubgp or 3800pro or regalgs.org
its an off the shelf cam cant be too hard to find.
lol cancel and find bigger cam its a sign its meant to be!!! at least go s1x but im reallllly biased for that cam hahahaha!!
I'd cancel just on principal... Any item they sell and ACCEPT payment for that is NOT in stock should require notification of back order. It isn't a good practice to do otherwise. I would contact them and say you've changed your mind and seeing as the item hasn't even shipped you want a refund! As mentioned, you can find those cams on re-sales and save even more.
Vs is such a waste for the price new. Now if you find a good deal on a used one then by all means, but buying a brand new VS cam is just dumb.
I ordered a metal harmonic balancer from them once, they emailed me telling me that Powerbond was no longer making the standard size balancer and they asked me if I would like the od one for the same price. Funny thing is you can still order the standard size Powerbond metal harmonic balancer from them, and every other vendor on the planet. My guess they lied just because it was out of stock..........
I ordered a VS cam for a build during the summer and it took three weeks because the Comp stock was behind.
It happens.
But, I've had my issues with ZZP in the past...however recently they've done a much better job at making up for the issues.
Built a motor for my old man's daily GTP...just a header/VS car with a stock pulley on a high comp block.
Better than rockers, and while the motor is out, why not?
Really? I would think "the aftermarket leader of the 3800" would grind their own cams. I mean they claim to have "The world's top 3800 technicians" so they have no reason not to do it.
