Off Road Racer with SC3.8 from South Carolina
The whole accessory drive will be custom so will keep that in mind. The transmission is a built 700r4 out of a 2.8 chevy blazer with a Custom 2:1 Atlas Transfer case. Last rig weighed 3800lbs. Hoping this one will be around 4000lbs
Alright guys well I finally got the parts for my 3800. The parts list is a 05 L32 with 89K, S1X cam, PAC 130lb spring, modified retainers, locks, balance shaft delete,42lb Lucas injectors, IRC Intercooler, Custom Headers, 75mm TB, LQ4 MAF, 10.4 Taylor 409 Pro Wires, AR103 plugs, Custom wiring harness and computer tune from Jim's Performance, Rod bearings, and all new gasket and seals!
Engine is Done.
L32 05 SuperCharged 3.8
Intense S1X Cam .514/.526 lift
130# PAC Racing Valve Springs
Balance Shaft Delete
IRC 2" Water to Air InterCooler with FMHE
75mm Throttle Body
75mm MAF
42# Lucas Injectors
Intense MPS 3" SuperCharger Pulley
Gasket Matched & Polished Intake and Heads
Aluminum Coolant Elbows
Clevite Rod Bearings
ARP Rod Bolts
Autolite Race 103 Plugs
Taylor Pro 10.4 Wires with Kevlar Boots Protectors
New Timing Chain
New Water Pump
New Alternator
New Starter
All new bolts and gaskets
Well i figured id update this as i have raced the rig twice now and the motor is holding up to the abuse. Here are some pics
Well i run a series 2 in my old buggy for 5 years but it was stockish. Everyone says i should have put a 5.3 or 6.0 in it but the power of a SC3.8 is Awesome from a dead stop which comes in great for limbing up vertical walls. I still think i can take a 5.3 or 6.0 thats stockish. I am taking my new buggy to 1/8 mile track this friday, will see what she runs
Looks awesome all together. Were those pics at KOH or Parker? How is the suspension? Got it dialed in for the higher speed sections or are you just running the rock races?
Those pics are from KOH, we are running all of the Ultra 4 East Series. Suspension is awesome for fast sections but have to work on it for the rocky sections its kinda harsh
Sent from my SCH-I545 using Tapatalk
