Obd2 port not working
04lss
Member
I've tried two Bluetooth scanners and a wired scanner, they won't even turn on. I've tried the ecm, sense fuse is there another fuse that might be blown
your port is fine its just picky. had a truck were the port wasnt reading the scanner but worked when we got it smoged so you may want to try a better bluetooth
I tried a scanner I used on another gtp, the scanner won't even power on. (This is a diagnostic scanner, the one that has a wire)
