CHI2000GTP
I will be buying a ODB tool to monitor my KR, although I'm running all stock at the moment. Looking at the BlueDriver unit for $100. Does anyone have any recommendations for brand and type?
My car is running but curbed as of this morning. Popped the hood to check some stuff out and noticed that my front exhaust manifold is wet, and the valve covers have developed a warp I did not notice until now. She's a real Fire Starter till I can replace the valve covers and get the gaskets done. Many of the ones I have seen on the internets are rather expensive. Any tips?
Along with valve covers/gaskets, I have a hole crap load of other things that need replacing that I have slowly amassed:
Lifters, valve cover gaskets, injectors, rack-and-pinion, s/c tensioner pulley and assembly, s/c smooth idler pulley, s/c grooved idler pulley, trans pan drop, trans filter and O-ring change, trans pan gasket change, TransGo shift kit install,
That weekend when I do this, is gonna be a LONG weekend.
Pics of warpped valve covers. Hard to see but you will notice bulges in the white plastic:
