chris99gtp
GTP Level Member
Just got the rotten egg smell . So the converter is bad right?
My advise is to have someone with a quality scan tool hook up the next time your light comes on. Check the freeze frame data captured by the PCM when it set the DTC. The reason I suggest this is: If the converter is failing, you want to make sure it isn't being melted down by something coming down the exhaust stream. A new converter will end up failing too if the problem isnt corrected. Not saying this is what you are dealing with but I would play it safe and have it scanned should the light come back on. Another possible fix is to find a shop that sells BG products and have them perform an intake and injector service. I have seen this service improve fuel economy and revive a sluggish catalytic converter. Just a suggestion.reset the code and it hasn't come on since how long should it take to go on? also does the converter ruin gas mileage
