More randomness,
@ NebTurboST5
First doesn't the engine RPM have a greater effect on keeping the m90 in its efficiency range than compression? In which case the rpm of the engine also effects turbo lag or lack there of than compression?
Compression of the motor has nothing to do with blower efficiency, however, higher compression and less boost (keeping the blower closer to its efficiency range) can give you the same power.
You can run more boost on a lower compression all things being equal? So if both had same rods since they are different between the non SC and SC engines..... All things being equal @ same boost level the lower comp engine would just make less HP if all things were indeed equal.....
yes this is all correct, thats why most stock gt's that get a turbo kit thrown at them make less power then most gtp's that get a turbo kit. the lower compression allows the L67 guys to run more boost right out of the gate.
To the OP what are the goals what is the budget? M90s are cheaper forsure but depending on how far you want to take it a turbo setup might be better in the long run if you want to make over 350ish whp. Also depending on what model you start with 1st decides more than just compression, it also includes transmission gearing.......(gearing a whole different topic depending on what power adder is being used.)
@ Reptile "Running a supercharged car that high without an
intercooler is knocking on the devil's door." NO ITS NOT....... there are exceptions I know you know this as well IT CAN BE DONE on E85 and stock heads I have @ 18 ish psi on a good day or so says the little aeroforce on the dash...... PSI is arbitrary anyways I could give a damn less what the car makes for boost, each engine is different and too many factors play into it to care such as pulley size, intercooled or not, ported or stock heads, headers or just a downpipe ect ect ect......
NONE of this is meant to start a pissing match but first of all What is the budget what is the goal and what is the starting model of the vehicle need to be addressed 1st!!!!
