Noise
gordster1122
On my 04 gp I replaced and when I turn the steering wheel I can hear a crunching noise or clicking noise can the cv axle be gone and need replacing and the abs and traction control light come on
Front
- Struts
- Inner And Outter Tie rods
- Control Arms
- Link Kit
Rear
- Struts
- Sway Bar And Bushings
- Trailing Arms
- Brake Hardware Kit
- Link Kit
I would check the wiring harness on both sides going to the wheel bearings. Which may be the reason for the warning lights coming on when turning the wheels.
Sent from my SM-G920R4 using Tapatalk
maybe you should stick your head under there while someone turns the wheels and try to pin point it, it could be ball joints tie rod ends hell even the strut mounts. or you gonna be just tossing money at it.
