noise from front end
Thanks Had the tie rod and sway bar replaced last year. You don't think it could be the struts never replaced (185,000 miles)
I had a similar problem , i did replace front with kyb mounts blah blah inspect them but my hydraulic motor mount was effffed so it was like metal on metal. Replaced and fixed. At 185k if you assume they havent been changed your mount almost certainly hasnt been changed. GL
