No start no security light on
Hot94z
Have a 02 gtp it started and died can get started with starting fluid put new pump in and new bcm had a blown passkey fuse but isn't blowing now I did the relearn and I'm getting to my end with it
Is the CEL on? Pull the vacuum line on the fuel pressure regulator and see if there is fuel in it. If so, replace the regulator. The only other thing that comes to mind is bypassing the fuel relay to put the pump into high speed mode if the fuel pump resistor has gone bad.
