Burbman
2002 GTP and both dash and tail lamps are out, while turn signals and headlights work. The "lights on" chime also dings whenever the door is open regardless if lights are on or off. I unplugged and re-plugged the headlamp switch and the problem went away! Everything worked normally and I chalked it up to a loose or corroded connector. Then the car sat overnight and the next day the same problem is back. No amount of wire-wiggling has any effect. I even got a new headlamp switch from the JY and no change. ideas?
