New build.
When i did my build i went from the ground up got a bit pricey machine shop and gaskets ,oil pump,lifters,timing chain and all that fun stuff were 1200
and now with 1000 soft miles and 1000 hard miles shes running good Still have the cam code bs ill wait till this summer to take it apart
The mains were a pain in the arse cause they are pressure fit and with out the puller tool lots of wiggling back and worth and gental prying
now you reminded me I should order lifters too.
Nick works 2 jobs, I work full time. Then I am stuck working on other peoples cars after work and never have time to work on my own stuff. The engine is out now. The timing chain was rubbing on the oil pump cover a bit so that is the metal shavings in the oil. Going to get the garage clean up tonight and work on getting everything back together.
