New Brakes, Squeaking/Grinding Coming From Left Rear
Well, it's almost been a week. I have begun to notice it fade slightly (the once per rotation clipping/grinding sound), but now when I am applying the brakes, they are squeaking.
take the wheel off. then go push the brake pedal. now go pull and push on the caliper it should move some. if it stays locked up tight, the piston is not moving back in freely.
you did say one rear piston put up a fight when you compressed it right? if its the same one it could use a rebuild or replacing.
I was going to do as you said on Sunday, Scotty, but it appears that the squeaking has gone away from my pads wearing down as stated earlier by you. Thank you for your help.
