New battery issues
Cenon
Hey guys i just recently bought a brand new battery for the winter. After installation its taking about double to triple to time to turn over. Does this have to do with higher CCR than my old battery??
every time i disconnect my battery, it resets the pcm, and it will crank over longer then usual. after a few starts, its back to normal. the trans may feel like its shifting differently as well as the trans relearns how you drive.
so if it does it again after you clean the terminals, let it go for a day or 2, it should clear up on its own, and be back to the 1/2 of a turn and start, like it was.
Alright so it basically needs to settle in huh? Well ill give it a clean and retighten, couldnt hurt.
Also the little wire that goes from the negative wire to the hood resistor(or w.e its called) whats it do exactly\
Hey guys, two days later the car starts up flawlessly. Still wondering what that little wire is there for.
