Neighbors 4t65 users a lot of transmission fluid
SgtMarshal
Active member
My new neighbor helped me move yesterday and has a 2001 gtp. He was saying he had to add at least a quart at every engine oil change. He hasn't noticed any leaks. What's the likelihood that it is a leak and just hasn't noticed or the transmission just uses that much fluid?
its in his rad for sure if not on the ground, trannys are a hydraulic pump, they dont burn fluid like engine oil, they leak it only.
The guy is a big dummy. He adds coolant a lot too. I'll probably help him change his lim gasket and all those other gaskets. It probably needs all kinds of basic maintenance
Still.. something ain't right if theres no visible leaks and the overflow hasn't overflowed with that much adding.
