T
TDCRacing
Guest
Just like it says. Just wantint to be sure where the power end is in the upper rpm range. I know it feels like it stopps pulling in the 6300-6500 range but just want be sure.
Our local dyno operater has you fill out a sheet with all the specs and rpm limit you want the engine rev'd to. You could tell him to make a pull to 6500 and if the power is nosing off earlier than that point then you will know by looking at the graph or print out after the pull. I am running the XP cam in my Cutlass and rev to the 6700-6800 mark with it but I also have very agressively ported heads which really help the top end. Most of the stock headed cars that I have put XP cams in seem to pull good to the 6300ish mark and I set the shift points at about 6350-6450 but every car and combo responds differently. In our old 95 prix with an L67 I had a VS cam and ported heads and its peak HP on the dyno was 5800 rpm while most stock cammed cars with rockers peaked about 5300-5400 rpm
