SyntheticShield
Okay, I got my blower motor resistor replaced, got a new ignition switch in, installed BackInBlacks ignition saver mod. I was cruisin' right along until I got to the point of actually putting the key back in:
The key cylinder will slide in, but it stops about 1/4" or so from going all the way back in. Ive tried moving it around and all that but its just not going.
Nothing has moved. I was DANG sure to put that cylinder away somewhere so it wouldnt get messed with and obviously I havent messed with the housing for the cylinder. It came out easy enough following the how to I have for replacing the ignition switch, but nothing was ever noted about getting the key cylinder back in, so Im at a loss as to what the trouble is or how to fix it.
Anyone that has replaced the ignition switch have any ideas?
