Need help with a handle
thenervemann
My car door handle on the inside i think is bent like the linkage stuff and the rods. Where do i get some new parts and what are they called so i can look them up?
Ed Morad parts should have some.........and I think that is what they are called. Inner door linkage rods..........just describe it and they can find it for you. Or your local junkyard. If you want new, I think only gm or gmpartsdirect would have them.
Okay im bring this post from the grave pretty much. But i have found that the screws where loose a little when i took off the interior of the door. I tightened them and is definitely better but its not like super solid like the other doors are. im thinking it isnt the linkage rod now.
instead of fooling with it why dont you go to a junkyard and get the whole assembly....your pullig your hair out for a 30 dollar set of parts
