charlie31603
Trying to figure out an oil leak on my Montana. It has a swapped 2006 3800 series 3, with a top swap from a 1998 series 2. When I put the motor in, I tore it down to a short block and replaced all the gaskets. Well it turns out I have an oil leak on the passenger side down low from the looks of it. It would only happen under boost. Had it on a lift running and never saw a leak. Even put dye in it and I could still never find the leak. I have replaced the front crank seal, oil pressure sending unit, oil filter housing gasket and just recently the oil pan gasket(I actually had the gasket in there and later found out it is only suppose to have rvt) But recently it got way worse and left me stranded on the side of the road twice. It just shot oil all over the belts causing them to come off. That is when I decided to do the oil pan gasket. But now I have a huge puddle of Mobil 1 ep all over my drive way and it still shots oil everywhere. And I still have no clue to where it is coming from. Is there any other spots that would leak oil like that in that area? I need to get this fixed asap! It is my only care that has a/c and that I can get in easily. Since I am now driving around going to job interviews. Any help would be great! Thanks.
