Hi all, heres my issue, I have a 93 grand prix 3.1. Last week I was on my way to class and it started fine. Backed up, put it in drive and it died. Wont start now. I have checked all my fuses, had a blown DIS and ECM fuse. Replaced those, Had fuel coming out of my throatle body and back into my breather, figered out that it was the fuel pressure regulator, replaced that. Changed the spark plugs and wires becase the the plugs looked really bad. I have 41 psi of fuel pressure at the rail and sigle to the injectors. Oh and I replaced the cam shift sensor. I pulled the idle control valve which was dirty as all heck, cleaned it as best I could and re-instaled it. The best I can get is if I turn the key to on several time quickly and the try to turn it over, but all it does is try to start and then nothing .... (sorry for the long post):th_depressed:
(P>S not that it really matter but I am a single father work part tiem and am going to school full time, i dont have a lot of money to try and fix this, but I need my car)
