my trans vs. turbo
99prixgt
club of used to own a gp
Since my car is no longer a daily...I have been considering to de-mod my m90 setup, ditch the L36 and go turbo/L67 instead. My trans was built by Dave and was installed this past December. The trans has the following upgrades...
-Intense input shaft
-Ls4 style chain sets
-HD diff
-stock gtp torque converter
I was really eying up the z7 kit from zzp and wanted to run my 1.9 yella terra rocker arms with it, even possibly spray meth/alky.
On another note, what kind of manifolds are you guys using? stock?
You at least need a rear turbo manifold and cross over. Your trans should be able to hold up pretty well.
If all you have is trans mods you listed I doubt you'll have it functioning for long. The LS4 cars eat transmissions like candy and I don't see anything beyond parts that come on the LS4 tranny in that list. Remember this is at 300hp and 323tq.
You can easily push past that with a turbo setup. Instead of a L67 you may consider an L32 as well, IIRC you will be starting with stronger internals.
Good luck!
I'm using the powerlogs front and rear if its not a daily I think that would be okay for awhile. You should hit up Dave see what he thinks.
-HD diff
your trans should be ok for a while.
many keep their m90 housing and remove the internals.
if you want a better flowing setup, you could go with an L36 LIM with injector holes plugged and L36 UIM.
