There is a Mobil station 3 miles away; along with several others within 7 miles, from my house distributing E85. ~$3.30/g over ~$4/g for 93.
I've been running Mototron 80#/hr (800cc) on my '04 CompG for the last month around with ~1k miles. I changed the fuel filter, same time I did the injectors.
I filled up 15 gallons of e85, for the first time on July 3rd. I'm using HPTuner and Scan Data Thingy to make adjustments and tweaks to the g/s vs hertz MAF airflow table, while logging my daily drives. I'm getting closer and closer to -5+ LTFT.
I must say, I noticed the engine ran smoother on e85 right from the get go, even better once I re flashed at least 3 times aiming for 0 LTFT since then.
E85 is a very beneficial route, whether its your daily driver or a race car. There are no disadvantages, as long as you have access to tuning software on a laptop with atleast 30+ min battery life.
I usually get around 300 miles for a ~15 gallon fillup on 93, I got 250ish miles on 15 gallons of e85, and I went WOT on the 3.2" 0*KR @ 15* a few times more than usual. Using HPTuner, my Injector Flow Rate cells are set to 66.99 g/s across the board. I'm running a stock fuel pump on a returnless fuel system.
