My suspension thread
they are alright. i think for how they ride they should be lower, but that is just me coming from an eibach car. a friend of mine has SSC on his car and they do just fine.
Time to get the thread back on track
So i just ordered a dorman front sway bar..now what?
i want to run poly bushings, where and which ones should i go with?
next will be the rear sway bar
should i just go with a gmpp bar and be done with it?
never could find the poly bushings but i moved on
Started pricing struts, springs, top mounts
now i need to find the pogo things, not exactly sure where and what those are
and i've seen boots and bump stops do i need to get those separately or does those come with the struts?
I just bought everything for my setup. The anti-pogo washers you can get straight from any GM dealer the part number is 10203412 listed as a "retainer". Typically the boots and bump stops come as a package. I ordered the monroe ones the PN is 63622 for the front and 63973 for the rears
while im in korea i piecing together my suspension parts. i have the GMPP sway bars and tower braces, DR tower brace brackets, and lowering springs. im ordering 97-03 LCA's so i can mount the front sway. trailing arms are next. ill put them one all at once so she feels new.
For poly bushings, I'd check Energy Suspension. I used the GMPP bar and all the info with pictures of boxes etc is in my Regal thread.
Little Update
Since i let this thread die
I got the front sway bar in and new tie rods on. Went to a new yard today and picked up a gm stb w/hareware now i need to find the brackets or drill the holes.
Anybody know what size bit/hole i need?
