My Bonneville. Retrofitted!
Thanks guys. The projectors are Mini D2S 3.0s with the X lens:
http://www.theretrofitsource.com/co...oto-mini-d2s-3-0-projectors.html#.VJXVP1KZCdE
I went with the ocular shroud:
http://www.theretrofitsource.com/co...ar-square-projector-shrouds.html#.VJXVaVKZCdE
I had to cut like 50% of it away to fit it into the reflector.
I was debating doing the fogs with the matchbox projectors, but instead I might do these LED housings once tax return money comes my way:
http://www.theretrofitsource.com/led-lighting/morimoto-xb-led-fog-lights-type-s.html#.VJXVoFKZCdE
Nice lights man.
Why did the shrouds end up slightly tilted, was that because they were suppose to follow the angle of the bumper to be level horizontal/vertical?
That dam driveway looks scary as hell.
Thanks!
They ended up tilted because they snap onto the projector in only one possible way. And for the output to be even, that's how it's gotta look. Oh well, I don't dislike the look. Love the performance of the MD2S 3.0 versus the MH1 I'm used to. They are noticeably wider.
The driveway isn't too bad, I never go in there with the Bonne unless I'm working on it. She sleeps outside. Gotta lay boards down or I scrape the nose.
Thanks!
You would think the cut-off shield would be parallel to the shroud(top/bottom) when clipped on. Then everything would be level.
