Re: My 2005 WRX STi - built motor, dom3, meth, fmic, plus 4 other subarus
An update for anyone who's interested, the car is up and running. I trailered it up to Buffalo to have the break-in tune done at the end of July and have been working out a few kinks since then. Overall the car runs really well, I've put about 1500 miles on it since first start, although I'm still on a break in tune with low timing, electronically limited to 5000 RPM's and wastegate pressure. I'm driving it back up to Buffalo in a few weeks to get the 93 octane power tune done. I wanted to do e85 this year as well but the stations here are already on their lower ethanol transition blends and I want to have the tune done of the highest ethanol content possible so that will wait until next year. Cobb is supposedly releasing full flexfuel integration by the end of 2015 anyhow, which will be really convenient it that's the case.
Anyhow, here's some pictures (lighting was very harsh):
I'm already wishing I would have gone with a smaller turbo, but hopefully with the cams and head work I can run it out a bit further before power starts to drop off. For now I'm looking to change up the wheels and pick up a factory wingless trunk. We'll see.
Here's the full mod list from the engine build. I added some other things as well, some more suspension/chassis stuff and I'm sure I've forgotten some things. I tried to do it all right, but staying with a stock location turbo was a mistake. Rotated offers better fitment and faster spool, but it's all together now and I'll run it this way for a while.
Engine Block
- 701 casting case halves
- decked
- bored to 99.75
- honed
- balanced rotating assembly
- new OEM heat-treated crank
- Wiseco 8.9:1 hard anodized pistons
- Carrillo Pro-H beam rods
- King XPG rod bearings
- King XPG main bearings
- ARP Custom Age 625+ head studs
- new OEM main bolts
- new OEM 10mm oil pump
- new OEM oil cooler
- new OEM oil pan and magnetic drain plug
- Killer B Motorsport oil pickup*
- windage tray
Cylinder heads
- Milled
- Full-contour valve job
- Backcut valves
- All valve guides replaced
- Spring installed height adjusted and set
- Performance spring locator and shim set
- Manley titanium valve spring retainer set
- Manley valve spring set
- Manley inconel exhaust valves
- Manley stainless intake valves
- bowls blended
- Cam journals polished
- Crower Stage 2 264 cams
- New OEM lifter buckets, sized (valves had to be tipped a bit as well to get proper clearances)
- new OEM Intake camshaft bolts
- new OEM Exhaust camshaft bolts
Engine cooling
- Koyorad aluminum radiator
- Silicone radiator hoses
- Killer B Motorsport Upper Turbo Coolant Reservoir
Engine miscellaneous
- NGK LFR7AIX gapped to .022"
- Gates timing kit with racing belt
- Gates racing accessory belts
- New OEM water pump (cast impeller version)
- New OEM thermostat
- New OEM Air/Fuel ratio sensor
- Fluidampr crankshaft pulley
- New OEM gasket kit
- Fel-Pro 26415 PT MLS head gaskets with LaserWeld Stopper Layer
Drivetrain
- Spec stage 3+ clutch
- Exedy 13lb flywheel
- new OEM flywheel bolts
- new OEM pressure plate bolts
- Goodridge stainless braided clutch line
- Cusco engine and transmission mounts
- Torque Solutions V3 pitchstop
- Motul gear 300 for the trans
- Motul 90PA for the rear diff
Fueling
- Russell -6AN fittings and hose from the firewall, routed 3-1-4-2
- IAG Performance fuel rails
- Fuelab 6 micron -6AN filter
- Aeromotive Fuel pressure regulator
- Injector Dynamics 1300cc top feed injectors
- Walbro 465 LPH ethanol-compatible in-tank pump
- Zeitronics ECA-2 Ethanol content analyzer with red gauge
- Breaking in on 93 octane, 93/E85 tunes after break-in
Power/support modifications
- Blouch Dominator 3.0 XTR 10cm exhaust housing, 3” inlet
- Swaintech White Lightning exhaust housing coating
- Tial MVS 38mm EWG
- IAG Performance wastegate bracket
- Grimmspeed EBCS*
- Moore Performance TGV deletes
- Moore Performance ported intake manifold
- Grimmspeed 3mm phenolic spacers*
- AMR cast aluminum turbo inlet with 3” coupler
- Omni Power 3 bar MAP sensor
- Killer B Motorsport Holy Header with EWG uppipe and Swaintech White Lightning coating
- Invidia v2 bellmouth downpipe*
- Borla XR-1 3” cat back exhaust*
- P&L FMIC
- KillerB Motorsport relocated oil fill tube
- Tial QR recirculating blow off valve
- KSTech MegaMAF 73mm intake
- IAG Performance AOS - competition version with pitchstop mounting bracket
- IAG Performance AVCS/Turbo oil feed line
- Cobb Accessport V3
- AEM UEGO WBo2
