My motor recently blew its a series 3 3800 on my 2007 grand prix anyone know the prices on them or if i should buy a supercharged motor and transmission im in west tennessee if anyone knows a place
Its much quicker and easier to find a L26 or L36 motor and make it pretty much a drop in unit. The L36 will require some part swapping to make it work good.
Don't make it difficult and get a supercharged motor and trans, because you'll just have a hugh headache on your hands and in the end it will likely never run.
the lim and upper intake and TB would be swapped over as well as your old injectors. and maybe a few other sensors that the plugs dont fit. not much really.
lower intake manifold, and the upper plenum, (lim and upper intake) TB = throttle body, ( where the air filter tube meets the engine) the TB bolts on to the upper intake, the upper to the lower intake.
if you get a older engine you want to change the lim gaskets to the up graded metal gaskets, so theres no extra work involved really. ( other then changing the lim over)
if you look around you should be able to find a l26 for rather cheap. they are in a bunch of newer cars, buick lacrosse uses them and a few others.
all those and maybe a few other sensors, you'll need to double check the rest of the sensors plugs and make sure they match your engines. egr, map sensor, knock sensors, and so on.
this is only if you find a engine thats a l36 the 97-03 engine. a l26 04 and up should hook right up.
Swap the rear exhaust manifold, and any secondary air injection if your car has it.
Swap the UIM and block the coolant ports on the LIM while you are there.
And depending on what you get it from, swap the flex plate. Some bigger body cars were 258mm converters, not 245mm.
If the motor is a 95-98 swap the alternator bracket.
Swap AC bracket if different
Swap oil pan if it's steel, yours is better.
