HVACgtp
Yeah I saw that you had mentioned that. I mean if the regular turn signal and the high beam will both flash at the same time, in which as long as I splice the 9005 bulb in I should be fine. Question is since I will need a load resistor for the switchback, will I need another for the 9005 bulb as well. I'd like to retain both as the turn signal, and obviously they can both run off the same wire since the amperage is minimal, I just have to see about the load resistors
