More stalling issues please read
saranykm
these cars are JUNK!
new fuel pump. new fuel filter. new resistor kit. new pressure regulator. new air filter. throttlebody cleaned. new throttle position sensor. new fuel relays-both of them.
driving this car off a cliff seems logical now...
after the new pump went in almost a month ago. it still stalled. i literally took the fuse box under the hood and slammed it against the fender wall causing the car to.....WORK PERFECTLY FINE! well fast forward to yesterday. car stalls while moving at a slower speed wait a while and beat the fuse box.....starts and runs.
the relays for the fuel are getting HOT what the fluff is going on with this car?
1997 gtp supercharged pile of crap
you may want to rent a fuel pressure gauge with a long hose, so you can drive the car and watch the gauge, if it looses pressure then stalls out, you know its pump related.
what brand pump did you use when you replaced it?
That's good... Let it all out! Releasing your anxieties is good!
By the way..., not junk, I own 3 GP's currently, one I was going to cut up for parts and runs like a charm so for now it's just another topswapped GP on the road.
good luck whatever you find to ride!
