comongoose
Okay I have a great question for some audio gurus. I need to power my two alpine type r 10" subs. They are both rated at 500 watts rms and have DVC so I can wire these two subs in any impedance configuration from 1 to 8 ohms pretty much. From my understanding It seems the higher the resistance the less distortion there seems to be. Anyways I am looking at two amps from the same company and they are the same price. One is a mono amp which is rated at 1000 watts @ 2 ohms. The other amp is a 2 channel amp which is rated at 1200 watts @ 4 ohms, when the two channes are bridged together. Now, everyone says that a mono is better for subs, since they are usually class D and high frequency distortion is irrelevant for subwoofers, but you want the efficiency to keep a small heat sink, and power. Well it turns out both of these amp are A/B circuitry amps. Which do you guys think is better in this case and why?
