asite57
There's no replacement for displacement![]()
more boost (safely of course)
Do you accept the challenge?
Boost is the replacement for displacement
I already accepted this challenge years ago. I just wanted to see what people would come up with when forced to explain themselves.
In short; A 300bhp ~250whp L67 with 1.9s has more low end, same mid range, and same top end as a stock LS4. They literally go step for step with each other. And of the dozens of dyno sheets I've looked at, when peak whp is the same or close to the same, the curves above ~4k are nearly identical. Under 4k, the L67 has a major advantage.
So actually because of the higher peak tq numbers of the L67, it will "feel" faster. Maybe that initial punch makes the top end seem less impressive?
What we've been told is that the v8 has more "top end" because the L67 falls on it's face.
So I'm wondering, if we compare the two dyno sheets, will the LS4 have a clear advantage in the "top end"?
300 is easy... it's over 300 where things start to get tough.
mike, what do u mean the v8 has more 'top end'? I was always confused about what people mean by that.
But you need valvetrain mods to make 300bhp... even if it's just 1.9s, right?
I'm still confused, is this a gearing thing or a power curve type thing?
So what you guys are saying is that if we compared a mild bolt on gp with 1.9s that makes the same whp as a stock LS4 that the LS4 will make it's peak tq and peak hp higher in the RPM range relative to the L67 and it will carry decisively more power into the redline?
Am I on the right track?
And you're missing the point. Regardless of gearing or power band a stock rocker 3800 tends to fall flat when you get to higher RPMs at highway speed. Rockers do wonders to awaken the "top end". You're not ribbing anyone. You're taking things out of context (purposely or otherwise) and then trying to show how superior your knowledge is. To anyone that's been doing this for any period of time your charade is pretty transparent.I just like to rib people when they say things like the L67 has no top end (in regard to power curve, gearing is a whoooooole nother' topic)
You're making my point for me... I said that adding rockers would alleviate the dead top end of the 3800.
Why do you ask all your questions as if you're setting someone up to tell them they're wrong? I've been here 3 days and I've already noticed this trend. Is this your standard operating procedure?
