Misfire Help Please!
very true, well I hope I don't have to take it that far but like u said I gotta keep diagnosing it as much as possible I'll probably try the sensors, throttle body screen and coil packs next I guess
Highly doubt it would be the screen honestly, one thing my dad did was when i had the car on he removed a wire at a time from the coil pack to see if they each had the same rythem of spark then put them back on, Personally i think it helps rule out the icm and coils at the same time.
ya personally I don't see how that screen could make all the cylinders to misfire that bad but I've been proven wrong before so ya I just wanna get this outta the way so I can continue modding, no sense in making it faster If it doesn't run right first
Lots of advice, I wouldn't do any of it until you no there aren't vacuum leaks. Vacuum lines have got to be the cheapest and easiest thing to replace and vacuum leaks will cause random misfires. I used a hand held vacuum pump and found almost every molded fitting was leaking a little, one was leaking a lot.
