t24moore
I just replaced some springs and rockers for a friend of mine. When I finished the install I started the car up and it ran okay but made a real loud tapping noise. I let it idle for a bit to see if maybe a lifter had not pumped up however the tapping continued. I removed the front valve cover and sure enough 3 of the rockers were not getting oil. So I loosened them up and re-torqued them. Then I started the car up to make sure they were getting oil. All but the one under the coil pack bracket on the exhaust side started getting oil. I moved the bracket back and retorqued that one again and when my helper went to start the car the engine would not fire. I checked the wires that go behind the coil and the ground was exposed along with a yellow wire that goes from the cam position sensor to coil pack bracket connection. I removed the harness striped everything off of it and fixed the two damaged spots and did a continuity test on all of the pins to make sure it was okay. Reinstalled it and now the motor seems to be running on three cylinders (2-4-6) only. To get the motor to fire I have to hold the throttle open and crank it for a few seconds. The motor will run as long as you give it throttle but shakes really bad. The only code in the PCM is the multiple misfire code. All cylinders have spark. The injectors have constant power. I dont have a noid light set yet but I used my tester light to see if the PCM is sending ground. I never seen the light come on. I also pulled the rail up to see if it fuel would shoot out when the engine is cranked and none came out except a tiny bit on cylinder three. I did a leak down test on all three of the cylinders and they check out good. I havent checked fuel pressure yet because my tester is missing. Im wondering if that yellow wire going to the cam position sensor shorting to ground damaged the injector driver somehow. I unplugged the cam position sensor to see if it would run fine and it still didnt. I dont have a pcm yet was just wondering if anybody has any other ideas or anything I might have missed. Sorry for the long story and thanks in advance.
