    TIPS:
Misc Bolts, Driver Side Engine Bracket
I'm looking at 2 coil pack brackets bolts(with the nuts on them), and the engine bracket right now in my garage. The bracket has 2 of the bolts in it, gotta find the third. I'll look to see if I can find the dogbone bolt for ya.
I destroyed mine, there was only two bolts there after It broke.
There was probably something else that attached the to third bolt hole that I deleted/no longer have.
Oh and to clarify, its the bolt that hold the individual coil packs to the ICM bracket. There's two per coil pack I need one.
Ok, well I have the bracket, 3 bolts that hold it to the head (found a brand new one and test fitted to my old junk head). Can't find the dogbone bolt/nut. Must not have come with my replacement engine. I'll check for the coil to ICM bolt (the tiny ones). Hold on...
I have 2 coil to ICM bolts sitting on my bench as I type. Checked to be sure they threaded into my spare ICM bracket to be sure the thread were good.
i got all that but the long dog bone bolt and nut. you could take the other bolt and match it up at a hardware store.
If nobody else has the long bolt by tonight I'll give the deal to fordman and just match up the last bolt at the hardware store.
Thanks for all the help you guys. Makes me realize what a great community we have here. I've been pretty busy lately and I don't have time to run around for little parts.
