Methanol injection
For normal amounts, it's best to put it in a tb spacer or drill and tap the blower housing for the nozzle.
Ok thank you so I could put it in the sc case I think thats where it will mix with the incoming air.I have seen picts with them in the lower intake but I dont think you will get a even mix just my thoughts
There is a thread on clubgp discussing location in the lim to put the nozzles. But for most, you are better off before the rotors. It'll raise the efficiency of the blower by doing so.
i have a nozzle 10 in evap port of gen v and 2 nozzle 3s in the lower intake just under the intercooler running a 2.55 pulley 23.5 deg timing
You could spray the meth to kill the KR; HOWEVER, you could also flood it out and overkill it. Get it tuned via a wideband and an in-car tune. Don't bother with the dyno crap. Then you'll know how it behaves on the street...toss on a smaller pulley...crank the timing, go from there.
