Map and Bar for L32
jbrltoliver
Need a big favor!! I am trying to get the part number for the Barometric pressure sensor. I cannot find it online or on Alldata. I can only find the 2 bar map sensor part on Alldata and Google. Anyone with an L32 under the hood could you kindly remove the sight shield and see what part number is listed on the Barometric pressure sensor.
When i pulled my top swap i pulled the map and baro assembly and used it and am now getting a CEL for them The Map and Baro i have on are the same part number as the 2 Bar Map. I am not sure if the Map and Bar are the exact same part.
Please advise, Greatly appreciated.
Delphi Part Number: 4724-05028483
Notes: Manifold Absolute Pressure Sensor -- Actual OE Part
Or you can just use google :cool:
PCM has an 05 GTP bin file. wiring is from 05 GTP from MOrad. Is the sensor not the same from 04-05 compG GTP, 06-07 GT( Supercharged )
