heres mine works great[/URL]
just a question, why did you go with the 4"?
i think i'm going to have to get a new piece of flashing, and do mine like urs, looks much cleaner than mine. i also bought my paint to paint my pvc.
When I made my similar fender well intake setup. I actually moved my AIT sensor down to where the hole in the fender well was and tapped into the PVC there for the sensor intake readings.
Here is a picture of mine when I did have it in there. I cut through the flashing to get to the tap I created and Gorilla glued a rubber gromet into the PVC so I could remove the sensor without issue when necessary.
Is there any way to do this with the 4" without removing/cutting the brace in the fender? If not, whatd you use to cut it? I've had a hell of a time trying to get the back bolt to take it out and just cant seem to get anything that fits back there
you didnt see my pcm right next to my coolant bottle , did you ? its right there in the pics. on the bottom of my pcm i used the sponges that came right out of the airbox to absorb impact or vibration and took a screw off my pcm cover and drilled it to my chassis again with the sponge in between pcm and chassis ..Hey i love this mod! I am going to try it out this weekend. A couple questions though;
Where does everyone mount their PCMs?
And also would i need to relocate my coolant bottle? (98 Grand Prix)
Thanks!
