Major oil leak!
FINALLY! Fixed...harmonic balancer was blown. Looked at it and it was definitely scored quite a bit...the seal was definitely spent...and I did find it was cheaper to just buy the timing cover kit as a hole than just the seal.
I've got an oil leak that leaks about 1/2 a quart every gas tank on my 2000 GP 3.8, no SC.
I had dealership change LIM and upper earlier this year, I just put a new front valve cover gasket on as I know that was leaking when I cleaned the engine up, but I think my pan is leaking.
I'm changing my oil pan gasket tomorrow and I can't find any links on how to do this. I found a writeup on autozone's website and I've seen where the 97-00 models you need to boost the engine up a few inches and remove the flywheel cover to get at all the bolts, but I'd love a video or writeup, especially with pictures. I've searched google and these forums, hoping someone can point me in the right direction. Thank you!
